97 Boxster Cruise Control Not Working
I have a 97 Boxster and the cruise control doesnít work. The green light will come on but when I press the stalk forward, it does nothing. Iíve only owned it for a few months and it hasnít worked during this time.
I changed out both the clutch and brake switches with no luck. I ohmd out both and they appear to be working fine. The fuse is good as well as all of the brake lights. I checked with the durametric and it doesnít give any codes.
Any recommendations as to what else I should check?
Old 01-13-2018, 09:33 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! You'll find a lot of very helpful and knowledgeable members here. Please take advantage of our DIY tech article directory, link below. I'm also attaching a link to an older thread where your cruise control issue is discussed; hope this helps and best of luck!
https://www.pelicanparts.com/boxster/boxster_tech.htm
Help!!! 1999 Boxster cruise control not working
Old 01-15-2018, 02:55 PM
Tags
boxster , cruise control
