Boxster "spare tire"
Does the "Red" spare tire from an up to 04 Boxster fit the 09?
Foolproof underestimates the dedication of fools
Old 11-30-2017, 01:41 PM
Dkennel's Avatar
that's an optional spare in a 997, will fit the same in a 987, you do need a jack, compressor and tools with it. Your biggest problem will be absolutely no place for your original wheel other than passenger seat maybe... otherwise you will have to leave your wheel behind...the folding tire has also only limited range and top speed...not very good option in my mind.
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 11-30-2017, 01:53 PM
The wheel I am inquiring about is the skinny wheel/tire that is already inflated.
Will the older ones from an 04 Boxster fit an 09 Boxster?
Old 12-06-2017, 05:33 AM
Occasional User
Cook&Dunning's Avatar
It looks like the skinny wheel is a 105/95/17 tire, 17 x 3.5 rim ET19. That would make the overall tire diameter 24.84" , which would be ~1 inch smaller diameter than the tires on your car - which probably is not a good idea. part 996.362.130.01
It is a large enough wheel, as the 987 base car came with 17" wheels. So the answer is it most likely will fit, but not sure I would do it.
Edit: Continental T135/80/17 from Tire Rack would give you an overall tire diameter of 25.5" Again, this is not a recommendation to do it.
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 12-10-2017, 08:28 AM
The spare is for an EMERGENCY only...Hopefully I will NEVER even use it, certainly not drive more than a few miles on it.
Old 12-10-2017, 10:21 AM
I have an 01, and before I go traveling with it, I'm going to spring for one of those tires. They're about $85 and are fresh rubber--my 01 spare is at least 16 years old. Not a good idea to trust any tire that old.
Brian Lamberts
Tucson AZ
Old 12-10-2017, 02:16 PM
Sorry, I veered off into irrelevancy, yes the compact spare would probably fit your 09, I believe the bolt pattern is the same. And possible wheel sizes were 17,18,&19 inches. The only complication might be if the spare would clear the brake calipers.
Brian Lamberts
Tucson AZ
Old 01-18-2018, 02:09 PM
