2000 Boxster S
I am having electrical issues...once the ignition key is out and I open the door the warning buzzer sounds, if I don't disconnect the battery it will die. The fobs don't unlock the doors or the trunk.....hope someone can steer me in the right direction.
Old 01-22-2018, 06:53 AM
boxzilla's Avatar
If your saying that removing the key is not shutting down the electrical system I would start by replacing the ignition switch. It's a cheap part that can easily be done. Instructions in this forum. As for the lock/unlock function of your key fob, that others may be able to chime in on.
2001 Boxster S
Trip/DRL/Debadged
2004 Cayenne Turbo
Old 01-23-2018, 07:08 PM
The insides of the lock gets gummy and full of crud. Cleaning them out with electrical contact cleaner or brake cleaner should help. Spraying in gun lube will work well to keep things loose. My lock took a couple of weeks to free up.
As for the fob, you may need to put a new battery in it.
Brian Lamberts
Tucson AZ
Old 02-05-2018, 11:09 AM
