Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
Question - Lifting 987 with Floor Jack
Good afternoon,
It appears undercarriage covers need to be removed to expose the reinforced lifting point interior to where the jack stands should be placed. How are the covers removed/reinstalled without first lifting the car? Thanks.
Wayne
Old 01-29-2018, 11:08 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Wayne - take a look at the link below to a tech article from our site; it should help you with the lift/jack points on your 987.
https://www.pelicanparts.com/techarticles/Boxster_Tech/01-BASICS-Jacking_Up/01-BASICS-Jacking_Up.htm
Old 01-29-2018, 11:17 AM
Thanks Dmitry Great article. It looks like the under carriage covers need to be off the car before you can access the reinforced area of the chassis (yellow arrow). Is that true? Thanks.
Old 01-29-2018, 12:12 PM
Administrator
No problem! Correct, any of the plastic pieces/covers need to be taken off before getting to the reinforced area.
Old 01-29-2018, 12:31 PM
Thanks, One last question. What is the procedure to remove the covers prior to lifting the car? Thanks for your patience.
Wayne
Old 01-29-2018, 12:48 PM
Screwdriver!
Or TORX driver
Take a look
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
'01 Boxster
Old 02-05-2018, 08:35 AM
Occasional User
I find it useful to use a pair of Rhino ramps to get the front or back of car off the ground to get some room to see underneath.
Vince
1989 911 Silver Coupe - sold
2009 Cayman S White, Full Cocoa Leather - sold
1972 911E Silver, Pepita & Black - sold
Old 02-05-2018, 08:47 AM
Thanks for your comments!
Old 02-10-2018, 03:31 PM
Gon fix it with me hammer
svandamme's Avatar
it depends where you need to lift it, rear is easier then the front, since most jacks won't go deep enough to reach those reinforced areas.
Rear, just lift on the suspension point to get the jackstands under the X
For most things I uses a pair of these
Can get the ass up high in less then 2 minutes ( a light cayman goes up quicker then that truck in the video)
Stijn Vandamme
EX911STARGA73EX92477EX94484EX944S88NOW987C2007
Old 02-11-2018, 10:18 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
