-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Gearbox Oil level (http://forums.pelicanparts.com/boxster-cayman-forum/986942-gearbox-oil-level.html)
kenward 02-08-2018 05:21 AM
Gearbox Oil level
Hi all
Can someone please confirm the gearbox fill oil level for a 2007 987 Boxster 5 speed manual gearbox, is it like the 986 and 11 mm down from lower edge of the fill plug? or fill till i trickles out?
JFP in PA 02-08-2018 09:16 AM
Originally Posted by kenward (Post 9918382)
Hi all
No, it is to 11MM below the fill plug hole. Fill it to the plug opening and you will end up with gear oil on your clutch.
kenward 02-08-2018 10:05 AM
Ok thanks
I thought it would be as the 986 but a local to me independant said until it runs out!
out of intreast how will oil end up on the clutch? blow a seal?
JFP in PA 02-08-2018 11:55 AM
Originally Posted by kenward (Post 9918821)
Ok thanks
No, with the level too high, the seal in the throw out bearing collar, which is not designed to be submerged, will simply let the excess oil drip into the bell housing.
kenward 02-08-2018 03:13 PM
Thanks for the info, appreciated.
Peter987 02-08-2018 08:06 PM
For a '09 Boxster S 6-speed are you still supposed to fill to the bottom of the plug?
kenward 02-09-2018 04:15 AM
Yes the six speed is till it runs out, wonder if Porsche just put the filler in the wrong place on the 5 speed!
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
