Gearbox Oil level
Hi all
Can someone please confirm the gearbox fill oil level for a 2007 987 Boxster 5 speed manual gearbox, is it like the 986 and 11 mm down from lower edge of the fill plug? or fill till i trickles out?
Old 02-08-2018, 05:21 AM
JFP in PA's Avatar
Originally Posted by kenward View Post
Hi all
No, it is to 11MM below the fill plug hole. Fill it to the plug opening and you will end up with gear oil on your clutch.
Accrochez-vous bien de vos rÍves..........."
Old 02-08-2018, 09:16 AM
Ok thanks
I thought it would be as the 986 but a local to me independant said until it runs out!
out of intreast how will oil end up on the clutch? blow a seal?
Old 02-08-2018, 10:05 AM
JFP in PA's Avatar
Ok thanks
No, with the level too high, the seal in the throw out bearing collar, which is not designed to be submerged, will simply let the excess oil drip into the bell housing.
Old 02-08-2018, 11:55 AM
Thanks for the info, appreciated.
Old 02-08-2018, 03:13 PM
For a '09 Boxster S 6-speed are you still supposed to fill to the bottom of the plug?
Old 02-08-2018, 08:06 PM
Yes the six speed is till it runs out, wonder if Porsche just put the filler in the wrong place on the 5 speed!
Old 02-09-2018, 04:15 AM
