Red face 2001 Boxster will not start but turns over
Hey,
Im new to posting on this site but have been reading for a couple months. I recently purchased a 2001 Boxster w/ 58K miles. Seems like it is in great condition but it is a few years old! I drove it Friday to work and when I came out to leave, it wouldnt start. It just keeps turning over. I came back to work with the Durametric tool and received the following codes. Any ideas? I have been reading allot about what it could mean in combination with the symptoms but have not replaced any parts yet. The codes are:
p1126
Porsche fault code 356 - Multiplic. mixture adapt. lower load range B.1:
I read that based on the symptoms, it could also be the Cranskshaft reference sensor. I also read it could be a bad MAF. Will the Boxster start if the MAF is bad? Can anyone confirm the following voltages for the MAF for troubleshooting (found these on another web site).
key on engine off: 0.9 - 1.1 volts
with engine idling: 1.2 - 1.5 volts
Old 02-18-2018, 05:44 PM
The engine will start and run (but not for long because you may foul the cats) with the MAF disconnected.
Old 02-18-2018, 05:54 PM
Thanks for the reply. I replaced both the MAF and Crankshaft reference position sensor. Still turns over but doesn't start. Does anyone know what the following code means for the Poster 2001 (From Durametric):
p1126
Old 02-25-2018, 07:01 PM
JFP in PA's Avatar
p1126
The P1126 code can be caused by:
- intake leak
- low fuel pressure
- contaminated injectors
- fuel pump failure
- exhaust leak ahead of O2 sensors
Accrochez-vous bien de vos rÍves..........."
Old 02-26-2018, 02:42 AM
Lots of fuel pumps failing lately...
Old 03-02-2018, 05:58 PM
That would be my first guess. Listen to see if it's running. Check for fuel in the fuel rail.
Brian Lamberts
Tucson AZ
Old 03-09-2018, 07:08 AM
- intake leak
- low fuel pressure
- fuel pump failure
Clogged fuel filter?
Brian Lamberts
Tucson AZ
Old 03-09-2018, 07:09 AM
JFP in PA's Avatar
Could be, but that would be a bit unusual; clogged filters normally impact running performance long before they would stop it from starting.
Old 03-09-2018, 08:13 AM
Turd's Avatar
In my 40,000 km in 7 years of owning a 2001 Boxster S I'm on my 3rd fuel pump. Im not a mechanic but they were easy for me to replace. I'm on my 3rd water pump too. I'd be replacing the fuel pump as a hopeful solution.
Old 03-11-2018, 09:30 AM
Tags
crankshaft sensor , maf , maf sensor , wont start
