Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
exc911ence's Avatar
Boxster interior water leaks?
Out of curiosity, how is the 986 Boxster for interior water leaks? I am currently looking at a Boxster locally that has really caught my eye but because my 911SC currently resides in my garage, I would have to park the Boxster outside. Because of this, and the fact that I live in the rainbelt, I worry about the interior of the car filling up with water.
I did a search both here and online but haven't found very many hits for this problem. Can I presume that if the roof is in good shape that the car will be mostly water-tight?
Thanks!
911SC... WideLoad Cab
Dave
Old 02-20-2018, 06:51 PM
M. Murphy's Avatar
There are cowl drains ahead of the windshield that must be kept clear and there are drains at the aft corners of the top that need to be kept clear. Failing to keep these clear will result in electrical damage as well as a stinky car.
Old 02-21-2018, 02:50 AM
Particularly in light of the most important control units are located under the passenger seat. You may want to think about a car cover to help minimize water intrusion, but absolutely check the drains for blockage.
Tony G.
2006 Cayman S
1986 911 Carrera track car...gone but still loved!
Remember Warren Hall. Contact me for your Warren 'Early S Man' Hall memorial decals.
Old 02-21-2018, 06:19 AM
exc911ence's Avatar
Good advice guys, thanks. My Dodge truck has the same issue with cowl drains plugging up (as do most other vehicles, I imagine) and rerouting water to my passenger side front floor mat so I'm quite pro-active on keeping them flowing.
Glad to hear that there's no Achilles Heel in the Boxster's design! Well, at least when it comes to water-intrusion.
Dave
Old 02-21-2018, 08:52 AM
M. Murphy's Avatar
One thing, be aware the front cowl drains empty in the front wheel wells. The way to clean them is to remove the front wheels and the covers in the front trunk over the battery and either side. Using low pressure compressed air blow back from the the wheel well drains, then vacuum out the debris from the top.
Under no condition push anything like a rod or screwdriver in the drains to clear something, I know!
Good luck.
Old 02-21-2018, 01:47 PM
exc911ence's Avatar
Good luck.
Good stuff, thanks!
Dave
Old 02-21-2018, 02:27 PM
