Upper console idler pulley replacement
The upper console idler pulley on my 2003 Boxster needs to be replaced and I have secured the proper replacement pulley. When I tried to remove the bolt, it is so long that it hits the body work where the engine cover attaches inside the cabin. Am I missing something or does removal of this bolt require pulling the engine? I guess this bolt is also used to secure the alternator, therefore, quite long. Any help is appreciated.
Jesse
Old 03-24-2018, 09:20 AM
Jesse
The bolt for the alternator IS very long but the bracket is slotted so that once loose, you can rotate the alternator out of the bracket. Check this out: https://www.pelicanparts.com/techarticles/Boxster_Tech/82-ELEC-Alternator/82-ELEC-Alternator.htm Follow their guidance. Wayne knows his stuff!
Brian Lamberts
Tucson AZ
Old 03-24-2018, 11:06 AM
Thanks Brian. I have Wayne's book,so I'll take a look and see if it makes sense to me. BTW, I grew up in Tucson. Left to join the military 45 years ago and haven't been back except for visits with the folks. Still miss the desert and the mountains.
Regards--Jesse
Old 03-26-2018, 12:20 PM
Gon fix it with me hammer
svandamme's Avatar
Don't know this specific bolt on the boxster coz i got a later cayman
But BTDT with the idler tensioner pully bolt.
It's a pain in the neck, and while unscrewing it
To the point where my ratched socket driver while screwing out hit the firewal.
I was unable to switch the ratched to screw back in. STUCK.
Busted my knuckles for more then an hour getting it back in with a vice grip...
fractions of a turn at a time
It's such a tightly packed car, if you don't have the right tool or do something out of sequence it's gonna be a bad day..
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-30-2018, 10:48 AM
Just as an update, I was able to remove the bolt for the idler pulley by beating on the bolt with a punch as pointed out in Wayne's book. Loosening the other alternator bolt allowed me to swivel the alternator enough to get the bolt past the bodywork. I found a guy on youtube, Burner's cars, who has a series of videos for his 2000 Boxster S. Pretty good stuff and very helpful. Take a look if you can. Thanks for the help.
Jesse
Old 03-31-2018, 09:07 AM
