Noise back right side
Occurs when I am moving and the car is not yet warmed up. It seems to vanish after driving to operating temperature. It's not a bang but more like something is rattling and occurs when I hit bumps in the road.
Any ideas where to start looking?
Thanks in advance.
Old 05-15-2018, 04:19 AM
Administrator
Dmitry at Pelican Parts's Avatar
Have you checked over your suspension - is everything on tight?
Old 05-15-2018, 02:58 PM
I believe so. Would suspension stop making noises when the car is warmed up?
Old 05-15-2018, 03:18 PM
I am going to throw this out there.
I was experiencing noise too when going over bumps.
I am pretty sure I found the issue when going to replace my clutch.
Upon removing the pan that fits under the transmission there were 2 large rocks stuck in there. I could not see them at all and had no idea they were there until I took the pan off.
Old 05-15-2018, 04:48 PM
Would the noise go away when the car warms up? Could the coolant tank be moving when cold and then stops moving when warm due to expansion?
Old 05-15-2018, 05:31 PM
SWC SWC is offline
One other thing to check is the exhaust, ie a cat internal baffle etc. Try hitting the exhaust with your hand before you start the car and is still cold to see if you can replicate the noise.
Old 05-25-2018, 05:30 PM
