Clutch Problems
Please Help! Replaced slave cylinder and have used Motive pressure to bleed air out of system. Bleed the system 1/2 dozen times (clutch up / clutch down). Each time I close cylinder bleeder valve, clutch only goes 1/2 way to floor. Hope someone with similar problem found solution
Thanks Mark
Old 04-29-2022, 05:58 PM
