Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
johnsonj
johnsonj's Avatar
My AOS Failure Symptoms
I know this is a common failure, wanted to post my experience hoping any insight might be beneficial to others.
Two days ago my 07 Cayman S started having a fluctuating idle after a long day of driving.
At home, I checked through Durametric, a lean condition was noted on one of the cylinder banks.
The next morning I took the car for a quick drive, everything fine at first, then fluctuating idle started again when everything was up to temperature.
When I pulled into the driveway the car started running roughly. Real time in Durametric showed multiple misfires on cylinders 4, 5, & 6.
After pulling the engine cover and starting the car it was easy to hear a vacuum leak (by now the check engine light was on due to the misfires).
I found the oil filler tube (the tube circled in red) was completely collapsed when running from the vacuum.
Pulled the piping for the AOS and found a lot of oil inside.
A new AOS will be delivered tomorrow - I'm fairly confident this is my problem. If not, I'll continue investigating.
A plug change and other cleaning is in order also since I believe enough oil was sucked into the cylinders to foul the plugs, strangely, it was only cylinders 4, 5, 6.
I did not have any puffs of smoke from the exhaust during the failure.
76 914
80 911sc Targa
81 928 Euro
07 Cayman S
Old 06-17-2018, 06:11 PM
johnsonj
johnsonj's Avatar
As a follow up, a new AOS resolved my issues. Although I haven't taken the car on an extended drive yet, I have no more misfires or collapsed oil filler hose.
To confirm I cracked the old AOS open and found the tear.
76 914
80 911sc Targa
81 928 Euro
07 Cayman S
Old 06-21-2018, 02:56 AM
glad you figured that out easily.
Old 06-21-2018, 04:28 PM
Tony911Z's Avatar
Thanks for posting this version of AOS failure. I experienced the far less subtle plums of smoke version on my '03 Boster S @ about 65k miles.
Tony Z
'78 SC, '03 Boxster S
Colorado Springs, CO
Old 06-27-2018, 04:41 AM
johnsonj
johnsonj's Avatar
Tonny911Z - no problem - mine failed rapidly, at around 72K.
76 914
80 911sc Targa
81 928 Euro
07 Cayman S
Old 06-28-2018, 03:49 AM
My car has a sort of lumpy idle, and very occasionally has smoked on startup, usually after not having been driven for a while. It also has a bit of a smell of burnt oil after a hard run. Are these possibly symptoms of an AOS on the way out?
Old 06-29-2018, 06:02 AM
JFP in PA's Avatar
Test the engine case vacuum level at the oil fill cap, if it is over 5 inches or water (fully warmed up), you will be the first to know.....
Accrochez-vous bien de vos rves..........."
Old 06-29-2018, 06:06 AM
How does one go about doing this? A quick search didn't turn anything up, but I may not be using the correct term.
Old 06-29-2018, 06:11 AM
JFP in PA's Avatar
You need a digital manometer (about $40) and a modified oil fill cap. Search other Porsche related websites, been covered many times.
Old 06-29-2018, 06:54 AM
JFP in PA's Avatar
Old 06-29-2018, 06:56 AM
johnsonj
johnsonj's Avatar
On my car, for testing, I plugged the hose from the AOS to the intake manifold - in the first pic, it has a yellow "dot" on it. After plugging it, my symptoms disappeared.
This was only for testing, to bypass the AOS, and and determine if it was the culprit - I only started the car (no driving).
*If you plug the hose, be sure to use an adequate plug, something which won't get sucked into the intake when you start the car.
If I would have had a manometer I would have used it instead.
Hope you find the cause~!
76 914
80 911sc Targa
81 928 Euro
07 Cayman S
Old 06-30-2018, 05:36 AM
