-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   engine harness: tip vs manual (http://forums.pelicanparts.com/boxster-cayman-forum/999871-engine-harness-tip-vs-manual.html)
dlud 06-18-2018 08:44 AM
I have a 2002 manual transmission with a bad engine. I sourced a 2000 tip engine. Question: will the engine harness for the tip engine work (leaving maybe some leftover and unused plugs for the tip ecu) or do I need to pull off my old harness and put it on the new engine?
Dmitry at Pelican Parts 06-18-2018 01:29 PM
Hello and welcome to the forum! Take a look at the link below to an earlier thread where this is discussed. Hope this helps you a bit and best of luck!
986 Engine Swap
dlud 06-19-2018 07:02 AM
Thanks Dmitry.
