Go Back   Pelican Parts Forums > Regional Forums > Canada
Car Addict
SOLD - 2 x Euromeister Fuchs 17x7
SOLD
I have a pair of 17x7 ET23.3 Euromeister Fuchs that were used for about 100kms and then put away as spares. THESE ARE LIKE NEW, there is one tiny nick on one (pictured) from tire mounting. The tires were removed, and these were put away on a shelf in the original packaging.
From the manufacturer's description:
  • 17x7" with 23.3MM ET (offset), 5x130mm lug pattern
  • Durable black powder coated centers with machined lip
  • 100% low pressure cast aluminum is lightweight yet strong
  • Meets SAE J2530 specs, tested for run out, balance, structural integrity, finish & size
  • Accepts original 70mm ring clip found on most Porsche® vehicles
  • Euromeister*® proudly presents these alloy replica 5-spoke style wheels. Manufactured using water & air cooled low pressure casting equipment resulting in the strongest and lightest cast aluminum wheels on the market. This design allows us to manufacture a wheel only slightly heavier than a more expensive forged wheel. Finished wheels are then completely X-rayed to insure quality and strength. Wheels come with black centers and a machined lip. All wheels are hub-centric with the standard 5x130mm lug pattern
Great quality wheels with an excellent finish. ** NO CENTRE CAPS ** they were a separate item and I didn't have spare caps.
They are USD175 each on Pelican, where I bought them. Just with exchange that's CAD230 each plus shipping plus HST - landed in Canada they are over $600 for the pair.
Asking CAD400 obo. Local pickup in Ottawa preferred, but will ship at your expense.
orange260z
2009 Porsche 911 Carrera S Coupe PDK Sport Chrono Plus
Porsche Racing Green/Sand Beige Full Leather
Old 07-21-2018, 09:12 AM
Car Addict
No interest in these? Make me a reasonable offer and they are yours!
orange260z
Old 07-29-2018, 04:57 AM
Puny Bird
Mark Henry's Avatar
Going to give these a try on my 914 narrow body, if they don't work out they may be up for sale again.
But I'm hoping they do work.
'74 Porsche 914, 3.0/6
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 08-15-2018, 05:54 AM
7s? Iffy.
Robert
Currently Porsche less (but the wife has 2)
Old 08-15-2018, 07:56 AM
Puny Bird
Mark Henry's Avatar
It's a good enough deal to have a look, right now I have 205/60-15 on 15x6" with 20 mm offset Fuchs
So 205/50 -17 with 23mm offset works out the same, but should push the tire out just under a 1/4".
The 50's are a hair taller but closer to stock diameter.
Might be close on the back of the rear tire. I'm OK with a slight pull/bead roll if needed, so they should fit without anything extreme.
Worth a try, I like my 15" Fuchs but the availability of 15" performance tires is almost non-existent these days and 17" tires are cheap.
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Old 08-16-2018, 01:53 PM
Puny Bird
Mark Henry's Avatar
Damn...they won't fit I need ET40 backspacing.
The 17x7 rims that work on narrow body 914 are EMPI rims, not near as nice looking as the Euromiesters.
My bad, sorry I have to pass.
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Old 08-18-2018, 02:30 PM
porscha
matty89's Avatar
pm u
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 09-02-2018, 01:07 PM
Car Addict
sold
orange260z
Old 12-06-2018, 12:47 PM
