Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Boxster modifications for import into Canada
I have browsed through a few of the postings and it seems that the required modifications for importing a US spec Boxster into Canada are the DRLs, speedometer switch, and the French airbag sticker. Am I missing anything?
Thank you in advance ...
Old 07-28-2008, 08:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
I just imported an Audi. The DRLs are a must. If the speedo also has metric on it, it should be fine, and my understanding is the airbag warning only needs to be in French if it requires routine servicing. I also believe a child tether is not needed on a convertable.
The RIV inspection took all of 5 minutes at a Canadian Tire. They never even brought it into the shop, just did it in the parking lot. Make sure they know where the sticker for the tire pressures are or if not pressent, you have a manual showing tire pressures.
Tim
1986 911 Cab
1993 Chevy 3/4 Ton
1997 Club Car
Old 07-29-2008, 08:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Purrybonker's Avatar
Same here, Canadian Tire guy (in the parking lot, 5 minutes in total) just checked the tire pressures on the door post and then stood in front of the car while I started it to make sure the headlights came on. I suppose I coulda just flicked the headlight switch on before starting it and he wouldn't have known the difference.
Boxster without PCM will require dealer intervention (or mod-kit discussed on the importation sticky), that should be about it. I don't think there are worries about the airbag stickers.
'06 C2S Cab
Old 07-31-2008, 08:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
avt007's Avatar
Google "Boxster DRL hack" and you'll find one for modifying a couple fuses- I did it, works great, costs pennies, and it's fully removeable later. Changing the speedo is built in to the display, just read the owners manual- no cost or dealer visit required. As for French stickers, nobody cared on my car. Good luck!
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 07-31-2008, 10:30 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
<insert witty title here>
Christien's Avatar
Some Canadian Tire locations sell the French airbag stickers, I'm told. Otherwise, find one on the internet or make your own in Photoshop, print and tape onto the passenger sun visor. Voila! It'll pass inspection. Same trick as the gear shift sticky on the dashboard for passing safety.
Current: 1972 911t 3.0
Past: 1986 911, 1984 944, 1999 Boxster
work: www.calfinancial.ca
music: www.christienledroit.ca
Old 08-04-2008, 06:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
