-   Canada (http://forums.pelicanparts.com/canada/)
-   -   FS: Engines, Engine Parts and Fuchs (http://forums.pelicanparts.com/canada/469228-fs-engines-engine-parts-fuchs.html)
Kevins911 04-15-2009 11:03 PM
It's amazing how much stuff you can collect over just a few years, time to get rid of some of it. There is a few things I didn't take pics of yet, but I can do so if thers any interest in the parts.
Local sales take priority, and all prices in U.S. plus shipping.SmileWavy
3.0L SC Crank, measured standard on both main and rod journals. $500
3.0L SC Rods, need to be cleaned up and rebuilt, 4 weigh in at 617g, 1 at 616g, and the other at 618g $100
E cams, perfect, with MFI drive $300
2.7L S CIS cams, 3 small pits on 3 of the lobes $30
T cams, 2 sets, early with no MFI drive $30 per set
2.2 T non c/w crank with rods $100
2.2 T cylinder heads, set of 6, non MFI, 46/40 valves, 32/32 ports $250
2.2 T pistons and cast cylinder set with wrist pins, no rings $75
2.0 T Cast cylinders, some look really nice with good cross hatching $25
'71 T engine harness, some of the insulation is kind of brittle, but good connectors $25
Carburator fuel bar, no plating left on it $20
5 blade fan $25
2.7L CIS alusil pistons and cylinders w/wrist pins and rings $50 SOLD
2.7L Distributor, 231 184 007, no points, rotor, cap or condensor, missing one clip $25 SOLD
Decent mag chain housings w/covers $25
Mag lower valve covers $10
'69 2.0L T short block, it knocked $100
'71 2.2L T long block, unknown history, no flywheel, engine tin or mount bar, valve cover to valve cover $off the market for now
Pair of 16x7 phonedials $30
Pair of 16x7 Fuchs, one is scratched/curbed most of the way around, $100
the other one has a little rash but otherwise decent $150
(mounted with snow tires, will remove)
Pair of 16x6 Fuchs, paint has been removed from centers, really nice and no curb rash $450
3 wheel spacers, 2x28mm thick $35 SOLD, 1x21mm thick $15
Kevin
http://forums.pelicanparts.com/uploa...1239864868.jpg
http://forums.pelicanparts.com/uploa...1239864907.jpg
http://forums.pelicanparts.com/uploa...1239864940.jpg
http://forums.pelicanparts.com/uploa...1239865012.jpg
2.7 CIS on the left, T's in the middle, E's on the right
http://forums.pelicanparts.com/uploa...1239865084.jpg
http://forums.pelicanparts.com/uploa...1239865166.jpg
http://forums.pelicanparts.com/uploa...1239865213.jpg
http://forums.pelicanparts.com/uploa...1239865356.jpg
http://forums.pelicanparts.com/uploa...1239865392.jpg
Kevins911 04-15-2009 11:06 PM
http://forums.pelicanparts.com/uploa...1239865529.jpg
http://forums.pelicanparts.com/uploa...1239865551.jpg
http://forums.pelicanparts.com/uploa...1239865578.jpg
http://forums.pelicanparts.com/uploa...1239865601.jpg
Kevins911 05-01-2009 10:12 AM
2.2T P's/C's
http://forums.pelicanparts.com/uploa...1241201359.jpg
http://forums.pelicanparts.com/uploa...1241201398.jpg
http://forums.pelicanparts.com/uploa...1241201449.jpg
http://forums.pelicanparts.com/uploa...1241201478.jpg
http://forums.pelicanparts.com/uploa...1241201524.jpg
