-   Canada (http://forums.pelicanparts.com/canada/)
-   -   Cleaing/TestingFuel Injectors (http://forums.pelicanparts.com/canada/619024-cleaing-testingfuel-injectors.html)
rvanderpyl 07-13-2011 06:19 AM
Any place in Calgary that can test and clean fuel injectors (from a 2.0 1974 914)?
Gunter 07-13-2011 09:22 AM
If the 1974 - 914 has Bosch K-Jetronic, just soak the injectors fully submerged in some good FI cleaner like Techron for 2 days, then blow them out with some air.
After that, to test spray pattern and volume in situ on the SC Bosch K-Jetronic, one can leave the injectors connected to the lines and place them into 6 equal-sized jars. Turn ignition ON, briefly lift the air flow sensor plate to make the pump run and hear the injectors squeal.
Works well with SC's but I'm not sure if that would works with 914's?
rvanderpyl 07-14-2011 09:42 AM
It is D-Jetronic, problem is that I am trying to get it running, and I am swamped, so I was hoping I could just drop them off and get them back, confirmed as good or bad.
