Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest Best Cleaner... Bar None
Before
Use with a 3M green pad
5 hours during a rainy Saturday morning
Result; Priceless
http://www.seventhgeneration.com/Shower-Cleaner
Who Will Live... Will See
Old 06-30-2010, 10:17 AM
JJ 911SC's Avatar
Well maybe not...
Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe)
Less than $5 a Liter...
Thanks Alex
Before:
5 Hrs, 2 Toothbrushes, a roll of paper towel & 4 rags later:
Old 01-09-2011, 04:11 AM
Hey JJ;
I followed your advice and bought a pail of AT30 today. I will post pics of my cleanup too!
Thanks for sharing!
Kev
Old 07-14-2011, 02:40 PM
Alps Adventurer
Traveller's Avatar
Originally Posted by KeoRS View Post
Hey JJ;
Thanks for sharing!
Kev
Just curious, but but is it up to in $$$ with/without tax?
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 07-14-2011, 03:35 PM
JJ 911SC's Avatar
I'm guessing that Kev pick it up in Ottawa (as he is across the river) so probably around 90 with taxes.
Old 07-14-2011, 03:47 PM
It was 88.00$ plus taxes. So ±99$ total.
Thanks to you too, Traveller (saw your post on Rennlist)!
I should have some cleaning done this weekend!
Kev
Old 07-14-2011, 06:39 PM
JJ 911SC's Avatar
While it's from here, down the US is a lot cheaper
Reverse of the Brad Pen oil which is cheaper here then South of the border
Old 07-15-2011, 01:56 AM
Alps Adventurer
Traveller's Avatar
OK JJ, KeoRS wants to meet up to "see who best used the AT30 to clean up the engine bay!".
Having replaced my 14 ignition wires on my 993 this past winter (where is that bang head icon), I had a chance to clean up the engine bay.
Getting to two of the four upper spark plug wire hold-down clamps is impossible without removing the right induction plenum and center connecting piece or as one well known Porsche guru put it, by loosening all six clamps connecting the induction plenums to the cylinder head spigots and pivoting the whole assembly upwards.
Well that is not the way I do things and I doubt it would give me enough room without some ham fisted antics, so I removed everything atop the engine and cleaned all parts and the engine bay. It also gave me a chance to inspect all rubber parts. Sure enough, the rubber on both clamps holding down the fuel injection cross-over hose and engine harness had dried out and crumbled when removed. They got replaced.
Initially these engine look "busy" until you start working on them and quickly realize how simple they are...
All the best,
Alex
Old 07-15-2011, 05:15 AM
JJ 911SC's Avatar
Originally Posted by Traveller View Post
OK JJ, KeoRS wants to meet up to "see who best used the AT30 to clean up the engine bay]...
No need to met over that
But you can drop by for a beer
Old 07-15-2011, 04:13 PM
Gillies's Avatar
Salut JJ, did you pick AT30 in Ottawa ?? If so where did you get it ??
Gilles...
1970 Targa 911T
Old 07-16-2011, 06:53 PM
JJ 911SC's Avatar
Salut Gilles
Oui. They normally have it in stock but I would call before going.
May be on the road... some time... This year
Have Fun
JJ
Swish Clean
2410 Don Reid Dr.
Ottawa, Ontario K1H 8P5
Toll Free: 1-800-267-5210
Tel: (613) 247-9550
Fax: (613) 247-9553
ottawa@swish.ca
Clean-it Centre Hours:
Mon-Fri 8am-5pm
Sat. 9am-1pm
Sun Closed
Old 07-16-2011, 07:23 PM
Gillies's Avatar
Thanks for the info !!
Old 07-17-2011, 03:25 PM
I started my clean up... just give me a few more hours of work and I'll post some before/after pictures
It's alot of work, but man does it clean!
Old 07-19-2011, 05:35 AM
Gillies's Avatar
Do you mix it with water or do you just spray on and scrub clean ??
Gilles...
1970 Targa 911T
Old 07-19-2011, 11:12 AM
Alps Adventurer
Traveller's Avatar
Although the product sheet states you can mix it at up to 200:1, obviously Facto AT30's effectiveness will decrease as a degreaser.
I've used it straight since I first started using the product (formerly named Swish Indo 505) back in 1986.
What I do...
The 20 liter pail of AT30 is a handful to handle so I screw a pump available from Swish for about $5 into the lid opening. Then I pump a liter or less at a time into an old plastic bottle.
When using the product, I pour small amounts into a plastic container like the bottom 3 inches of a windshield washer bottle after its been cut off. When washing dirty greasy items, then only a small amount of the degreaser gets dirty as you dunk the paintbrush or toothbrush into the smaller container repeatedly....you end up wasting less AT30.
Rinse with plenty of water.
If you are as picky as I am, place a strip of heat shrink tubing around the metal band of your paint brush. This prevents any chance of it scratching any painted surface.
Old toothbrushes are invaluable.
All the best,
Alex
Old 07-19-2011, 02:56 PM
Just a little update.
Before:
In progress:
Booyah!
Old 07-19-2011, 03:24 PM
Gillies's Avatar
Looks good...I will keep that in mind when I get into the cleaning mode.
Gilles...
1970 Targa 911T
Old 07-19-2011, 06:12 PM
JJ 911SC's Avatar
I think yours was worst then mind...
Keep going
Old 07-20-2011, 05:06 AM
19 years and 17k posts...
azasadny's Avatar
Nice work, guys!
Old 07-31-2011, 11:23 AM
Alps Adventurer
Traveller's Avatar
Here is another great product from Swish.
Swish Facto AT34 Aluminum Cleaner & Brightener.
It is used on aluminum, but I have used it on the back sides of my wheels, both on the painted and bare aluminum surfaces.
No before pics, but we all know that it is next to impossible to get that grime out from the cavities on the back sides of the spokes and also the hub.
All the best,
Alex
Old 09-10-2015, 08:38 PM
