Pelican Parts Technical BBS
Pelican Parts Technical BBS (http://forums.pelicanparts.com/)
-   Early BMW Cars (2002, Bavaria, etc.) (http://forums.pelicanparts.com/early-bmw-cars-2002-bavaria-etc/)
-   -   5 Speed (http://forums.pelicanparts.com/early-bmw-cars-2002-bavaria-etc/595846-5-speed.html)
TA2PEEL 03-08-2011 07:21 PM
5 Speed
If I just came across an old 5 speed from an old 3 series. would that be a straight swap from my old 4 in my 76 2002? I have been told the drive shaft is shorter for the 5 speed, is that the only change that must be made?
RatBox 04-11-2011 03:36 PM
see what a google search will get you :
BMW 2002 Transmission FAQ
"5 Jan 1997 ... Installing a 320i five speed transmission into a BMW 2002 ... 1 2002 close ratio 5 speed mounting crossmember, or you can modify the ..."
POPS 83 944 11-21-2011 09:56 AM
No you would have to shorten drive shaft and shifter linkage
speed_pro 08-12-2012 10:17 AM
Certainly.. you have to shorten the drive shaft!
Rusty 356 12-29-2012 11:30 AM
Trans mount is moved a little rearward. there is a piece to buy from one of the bimmer shops.
shift tower has to be moved and shaft shortened.
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website
