-   General Car/Truck Questions & Discussion (http://forums.pelicanparts.com/general-car-truck-questions-discussion/)
-   -   I need some help removing my fuel rail (http://forums.pelicanparts.com/general-car-truck-questions-discussion/391081-i-need-some-help-removing-my-fuel-rail.html)
Arizona_928 02-04-2008 06:05 PM
i recently just bought my first car. a 85' 944. and one of the things that needed to be done is the camshaft gasket. i started to remove the fuel rail, and can't figure out how to get it off. i depressurized the system, disconnected all the hoses, & bolts. the manual i have says to pull it strieght up. but it seems the back 2 injectors won't come off. the front 2 are loose, and are willing to come off.
i know it had a light engine fire. that burned through 1 of the rubber lines. it might have melted the the injectors in the manifold? any-who is it safe to use a screw driver to pry them loose? any help is welcomed
Arizona_928 02-06-2008 10:37 AM
i was able to figure it out. the injectors over 3 & 4, were melted in.:eek:
