-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   R56 n12 non turbo no start (http://forums.pelicanparts.com/mini-discussion-forum/1000343-r56-n12-non-turbo-no-start.html)
Warmage 06-23-2018 07:12 AM
Hello,
I hadl a pump fail and replaced it and the filter, cleaned the injectors and engine still wont start.
I can see fuel if i remove hose from fuel rail, but injectors barley sprays fuel
Atm i have to fuel pressure gauge will need month to get it
Anyone know what else i need to check? Is there a fuel pressure regulator in this mini? Non turbo
Or if there is somthing that will stop the car from running the injectors?
Another thing how many volts will go to the injectors on start up?
No error codes
Warmage 06-25-2018 08:34 PM
i checked fuel pump connector voltage its 10.9v with load , battery reads 12+v
but voltage at fuel injectors are 7v only , and the car cranks full power for an hour before i drain the battery
anything else i need to check ?
