-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   ECM low output signal Voltage (http://forums.pelicanparts.com/mini-discussion-forum/1008101-ecm-low-output-signal-voltage.html)
Isomj 09-17-2018 06:48 PM
2009 R56 non turbo....starts fine ...power drops off bad after 5-10 seconds of running..last code was a Knock sensor low voltage. Output of terminal 33 at computer is only 1.6 volt....checked output of some other terminals was only 3.6 volt but I can get a 5 volt signal on the cam sensors...ECM gong down but still enough to run the vehicle?????
