2010 Mini Cooper S
Hello,
2010 Mini Cooper S will crank but not start. Replaced various parts: Battery, Temp sensor, Cam sensor, Crank sensor, Plugs, Fuel Filter, Fuel Pump, High Pressure fuel Pump and DME also checked. Could use some help, any suggestions? Thanks |
Administrator
Hello and welcome to the forum! Have you pulled any stored fault codes?
Have you gone over to northamericanmotoring.com?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Thanks,
I will check them out. Thanks |
2010 Mini Cooper s
A foreign car shop stated it had low fuel pressure and that led me to replacing the fuel pump, fuel filter and HPFP. It still cranks but not start. Your thoughts? |
