-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   2008 mcs r56 cts issue (http://forums.pelicanparts.com/mini-discussion-forum/1045310-2008-mcs-r56-cts-issue.html)
G60polo 11-17-2019 06:50 AM
Fan runs constantly, changed coolant temp sensor, no change, changed map and maf sensor no change
Measured voltage at plug and ecu terminal 32 and only 3 volts.
Is this correct or should it be 5v
Continuity through wire live and earth.
Bit stuck now 14v at battery.
Can I take 5 v from else where to test. If so where?
Hidden menu page 7 cs mom just reads *****
Rush2252 11-25-2019 01:08 AM
Any chance you have the plug swapped on the CTS? The wrong connector on it and you will have fans running all the time or if you have a broken wire. How many wires are going to your CTS?
