2010 Mini Cooper misfire 1,4
engine(DME/DDE)codes 4
2781 combustion Misfire several cylinders 2779 combustion misfire cylinder 4 2A7D oxygen sensor after CAT Electric 2771 Combustion Misfire Cylinder 1 Junction Box Electronics (JBE) code1 A87E ULTRASONIC Sensor,Line Fault OBD2 Engine codes 2 P0300 Ramdom/Multiple Cylinder Misfire Detected P0304 Cylinder 4 Misfire Detected daughter said that car died battery was dead she could have been sitting there with lights on charged battery now all these codes replaced coil pacs and plugs Help |
You will need a scanner capable of reading bmw specific codes. You will also need to clear the codes and probably register the battery. They are very fickle. You have to register a replacement and make sure to get the correct size if it was replaced. If you jumped it off try clearing the codes and seeing if they come back.
Any resolution?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
