-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   07 Cooper S won't start after new injectors installed (http://forums.pelicanparts.com/mini-discussion-forum/1048885-07-cooper-s-wont-start-after-new-injectors-installed.html)
MendoAbDiver 01-02-2020 04:13 PM
[/U]Correction 2007 MINI not 08[/U]
I was traveling down the highway at 70mph when suddenly my MINI started running rough. Without a code reader I diagnosed 3rd cylinder misfire but not why, later a code reader confirmed that with a P303 code. Installed new plugs and coil packs and still misfires and still just a generic P303 misfire code. I installed all 4 new Bosch injectors and high pressure fuel line. Now it will not start, just cranks over and over. No codes on the code reader to help out. No fuel leaks. Any ideas about the most common problems or how to diagnose this would help.
Nic900 01-07-2020 07:40 AM
Could it be air in the fuel line or pump? Might need bleeding
MendoAbDiver 01-15-2020 02:55 PM
Will try that. Thank You
