-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Broken Crankshaft Damper (http://forums.pelicanparts.com/mini-discussion-forum/1050802-broken-crankshaft-damper.html)
speedman 01-24-2020 09:46 AM
My 05 MCS has destroyed the rubber centered crankshaft damper. I have a new one from ATI ( Super Damper), but when i install it the new damper slides right on. This cannot be a good thin. I am thinking I will pin the damper to crank. Is there any other ways to make this repair without having to remove the crankshaft?
j911brick 02-05-2020 10:30 AM
What did you do?
speedman 02-05-2020 12:18 PM
I will try a repair this weekend. I will drill the damper and crank to accept a removable dowel pin. A bunch of companies that sell supercharger conversions have you pin the crank, so I think it will work. I have not seen any issues the way it is right now, but a MC mechanic told me that if the damper slips it will cause the car to throw an error code. I have a reoccurring P1498 that comes and goes
