Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
2010 Mini Cooper misfire 1,4
engine(DME/DDE)codes 4
2781 combustion Misfire several cylinders
2779 combustion misfire cylinder 4
2A7D oxygen sensor after CAT Electric
2771 Combustion Misfire Cylinder 1
Junction Box Electronics (JBE) code1
A87E ULTRASONIC Sensor,Line Fault
OBD2 Engine codes 2
P0300 Ramdom/Multiple Cylinder Misfire Detected
P0304 Cylinder 4 Misfire Detected
daughter said that car died
battery was dead she could have been sitting there with lights on
charged battery now all these codes
replaced coil pacs and plugs
Help
Old 11-13-2019, 02:13 PM
You will need a scanner capable of reading bmw specific codes. You will also need to clear the codes and probably register the battery. They are very fickle. You have to register a replacement and make sure to get the correct size if it was replaced. If you jumped it off try clearing the codes and seeing if they come back.
Old 11-13-2019, 11:16 PM
j911brick's Avatar
Any resolution?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 01-18-2020, 06:45 PM
