Dash Warning Lights Won't Go Out
I own a 2006 plain Mini with just over 100K
Last spring I replaced all brake pads & rotors Also ended up replacing all four bearing hubs since the rotor set screw would not come off. Only way to replace the rotors was to remove with the hub. Put everything together but did not install replacement bake wear sensors. For the past year have been putting up with the following warning lights on the dash: ABS Low tire...….tried resetting with button numerous times Brake Sensor Mini runs great with no ABS or brake issues With being stuck at home with the virus crisis decided to replace the break wear sensors today Still getting the same warning lights plus the Emergency Brake light won't go out now with the handle released. Any idea what's wrong? Are their resets I am not performing It's a pain seeing those dash lights and not appears wrong with the ABS or brakes and no low tire pressure |
Liights
WOW...…...688 views and not one "Reply"
