-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Help please stuck with code 2C57 (http://forums.pelicanparts.com/mini-discussion-forum/1064057-help-please-stuck-code-2c57.html)
Fiercefury666 06-13-2020 06:22 AM
My Mini cooper R56, 2010 , N-18 engine stuck with 2C57 Code
I have read another topic about 2C57 code and I did everything as list below :
1. Changed Diverter Valve
2. Changed Pressure Converter
3. Changed Vacuum pipes (#1 from vacuum pump and #2 Waste gate)
I already tested wastegate flapper with bore scope at vacuum pressure @ 15" and it close as normal
My next plan is change both VANOS solenoid.
I need a suggestion from everyone to help me solve this problem
