embrayage
manuel pour dépose boite de vitesse countryman type r60
embrayage
comment depose une bv sur countryman r60 merci
bjr comment depose un bv countryman r60 merci
Google Translate tells me that Mr. allaudien would like to know how to remove the gearbox on his R60 Countryman so that he can inspect or replace his clutch.
It looks like the Bentley service manuals do not cover the Countryman models, which is a shame. The manual for the Cooper might be good enough, but that's a lot of money to spend on "might be". You might see if our Tech Article for the Cooper models is close enough. https://www.pelicanparts.com/techarticles/MINI/25-TRANS-Clutch_Replacement/25-TRANS-Clutch_Replacement.htm Other than that, I don't have any information for you. --DD |
| All times are GMT -8. The time now is 02:46 AM. |
