Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
2006 Mini won't Crank
Asking a question
Need some help troubleshooting
Our 2006 Mini started & ran great Friday
Went to use it Saturday
Pushed down clutch.....turned key......dash lit up......starter motor made a few turns and that was it
Tried again.....a few turns of the starter & quit
Checked battery and was at around 12v
Put trickle charger on for a few hours and battery up to nearly 14v
This morning.......Pushed in clutch......turn key.....dash lit up but no starter engagement
Battery is less than a year old
Any ideas on what may be cause?
Does not look like a fun job to replace the starter
Also.......is there a switch/relay on the clutch pedal to that must engaged before turning the key to allow power to the starter?
Old 03-07-2021, 09:21 AM
Administrator
Luccia at Pelican Parts's Avatar
Did you plug in to see if there are any codes stored? Honestly... bad batteries make these cars do some seriously weird stuff. Might not be a bad idea to start there. I have seen MINI's batteries read at 12-13v and need replacement. This article can be very helpful to you: https://www.pelicanparts.com/techarticles/MINI/57-ELEC-Battery_Replacement_and_Battery_Tender_Installatio n/57-ELEC-Battery_Replacement_and_Battery_Tender_Installatio n.htm.
Old 04-01-2021, 12:46 PM
