-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Coolant Bleeding (http://forums.pelicanparts.com/mini-discussion-forum/1121604-coolant-bleeding.html)
alan_v 06-25-2022 08:32 AM
Coolant Bleeding
I have to replace the t’stat housing and coolant temp sensor (CTS) on my 2011 R56 with a manual trans due to coolant leakage. The procedure in my Bentley manual says that the system can be bled by alternately filling the system and running the engine at idle. However it also warns that if the system doesn’t bleed properly, a vacuum bleed would be required.
1. How successful is bleeding without vacuum in the R56?
2. As I’m replacing the CTS as well, would initial filling with the sensor removed aid in bleeding it completely?
TIA
Matt at Pelican Parts 06-29-2022 12:43 PM
Hi alan_v!
Although vacuum bleeding certainly does make bleeding the cooling system a much easier project, generally in most cases no, you should not need by necessity to remove trapped air.
Usually this is for when there is a bubble trapped deep within the system. Sometimes with pesky bubbles like that you can get away with jacking up the front of the vehicle and letting it sit overnight with the cap and bleeder screw off.
Anytime you disturb the cooling system it needs to be properly bleed so you're best off replacing the temp sensor and thermostat at the same time and then bleeding the system after.
It's great you have a Bentley manuals as those are an awesome resource for trusted information. Also check ou our DIY article on the subject. If you scroll down to figure 8 you will find some tips:
https://www.pelicanparts.com/techarticles/MINI_R56/56-WATER-Draining_Filling_Cooling_System/56-WATER-Draining_Filling_Cooling_System.htm
-Matt
