Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brake light with "Lift" symbol. 09 Clubman
Been seeing the Brake light right by the 20MPH on the speedo & now the lift symbol is coming on. Today I got out the Schwaben code reader & it said fault in the ABS and offered a part number of 6778350. I put that number into the website here and saw a lot of pads, thing is mine are all fine. What is that number really, or how do I trace it???
Old 05-01-2024, 07:42 AM
Just ordered a brake pad ware sensor wire for the rear, that is the only questionable thing I can see. Sure hope someone comes along with some input on other possibilities for this issue - I'm too old to be left along the side of the road with a broken car~
Old 05-01-2024, 09:07 AM
If your code reader indicates that you have a abs sensor issue then a brake pad wear sensor will not solve the issue.
the code reader should also tell you what sensor it is.
to track down a part number you can use the website real oem.
what exactly did the reader say?
1976 914
1986 951
Old 05-01-2024, 11:13 AM
What it says is: ABS/ASC/DSC Dynamic Stability Control - Fault Then, if I hit enter I get a list of options with the part number being the only option with info to read. The number being 6778350 which I'm going to run now~
Old 05-01-2024, 01:21 PM
I'll try realOEM when I get the vin out of the car. I just looked on ebay and that part number showed up as an ABS control for Renault, there's a bunch of them in Spain, why only Spain?
Old 05-01-2024, 01:40 PM
