Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brake, ABS, & Traction Control Warning
I have a 2001 740i w/ 70,000 miles. For the past several months, the brake, ABS, and Traction control warning lights come on intermittently, usually after driving for a few minutes, sometimes when the car is first started. Turning car off and re-starting can reset the warning lights, although not always.
I have been told several things could be causing this ranging from the alternator going bad to the brake fluid should be changed.
Anyone else experience this, and can you help w/ the solution? Wheel sensors going bad?
Suggestions appreciated.
Old 03-05-2009, 07:15 PM
