-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   harmonic Balance (http://forums.pelicanparts.com/mini-discussion-forum/670026-harmonic-balance.html)
vernramey 04-06-2012 09:18 AM
harmonic Balance
Do I need a special tool to Remove? 1999 528I
Jared at Pelican Parts 04-06-2012 09:48 AM
On that particular engine, I believe the balancer is held on with six 13mm bolts.
You'll need to keep the engine from turning while you loosen the bolts. Give me your VIN number and i can confirm.
vernramey 04-06-2012 04:05 PM
wbadm6334xby21869
vernramey 04-06-2012 04:07 PM
yes there are six 13mm bolts, them are out do I need a puller once I take them out
Jared at Pelican Parts 04-06-2012 05:54 PM
Pretty sure you dont need a puller.
