-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Change (http://forums.pelicanparts.com/mini-discussion-forum/746441-question-coolant-change.html)
Shawn (guest) 04-24-2013 05:12 PM
Where is the 3rd bleed screw you refer to on the R50 motor? I found the 2 you show in pics 16 & 17 but you don't mention where #3 is. Please respond. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Coolant Change
Nick at Pelican Parts 04-24-2013 05:12 PM
There are two bleeder screws you should open. One at the hose on right side of engine and one at the thermostat housing. This applies to supercharged and normally-aspirated models.
- Nick
