here is my question: when you jack the car both front and rear wheel come off the ground on the jack side. can you tell me how one gets just the front up on stands? I can imagine that you could use two jacks one on each side in synchrony but i envision as you get the stand on one side set when you move to the other side you would not be able to fit the jack underneath to place the second stand. thanks for the help
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Jacking Up Your MINI |
You can jack under the front crossmember, jacking just the front of the vehicle. be sure you are on the crossmember and not the engine oil pan or other items that could be damaged.
- Nick |
| All times are GMT -8. The time now is 02:04 AM. |
