There is a drain plug on the back side of the engine just above the starter motor. This plug should be removed to drain the fluid in the engine block. Your directions are simply draining the radiator. The power stearing fan will need to be lowered. Good luck, Mike
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Coolant Change |
Thanks for the info.
- Nick |
| All times are GMT -8. The time now is 07:59 PM. |
