Thank you for the article. It was invaluable. I did find that it is not necessary to remove the starter, only the two mounting bolts.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement |
Thanks for the tip. You can hang the starter of out the way when removing the trans.
- Nick |
| All times are GMT -8. The time now is 10:39 AM. |
