Thanks for your great info, i just replaced both bushings with frame and i found that to remove and re-apply the bushings on the control arm it will be easier and faster if you use a pully system, it took me 10-15 minutes.
And to loosend the bolts use a wrench extender for the driver side. __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Control Arm Bushing and Ball Joint Replacement |
Thanks for the additional information.
- Nick |
| All times are GMT -8. The time now is 10:30 AM. |
