Hi, My window doesn't work up or down I do everything but I can't lower the window to removed the sprockets.
How I lower the window manually? __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement |
If you can access the window motor, disconnect it fromt he window regulator, then push the window down by hand.
- Nick |
| All times are GMT -8. The time now is 03:25 AM. |
