Oh, by the way. Instead of the GM puller you can use a caulking gun. Most everyone has one or two around their house.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Replacement |
Not a bad idea. Only issue would be the risk of damaging the slave cylinder. It is made out of plastic and too much pressure on the fitting side could damage it. Using the puller allows you to pull against the mounting flange that is designed to take stress.
- Nick |
| All times are GMT -8. The time now is 10:34 AM. |
