Can you not use a vacuum bleeder on the slave cylinder?
I ain't seem to suck fluid out from the line. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes, you can use a vacuum bleeder.
I like to fill the reservoir, then open the bleeder and let it gravity bleed for a while. Then bleed the normally. If it gives me trouble bleeding I will usually pressure bleed it. - Nick |
| All times are GMT -8. The time now is 09:28 AM. |
