-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Underdrive Pulley Install (http://forums.pelicanparts.com/mini-discussion-forum/765949-question-underdrive-pulley-install.html)
Bryan (guest) 08-14-2013 05:05 AM
Just curious what you think about an overdrive crank pulley 2% with the 15% under drive SC Pulley? Will this damage the alternator or electrical system? Also, I don't see any procedure for replacing the timing chain, guide rail, tension rail and tensioner. Is this something good to do since I have my Mini S in pieces right now? 2002 Mini S R53. Thanks. Can't wait to get your book for my Boxster!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-14-2013 05:05 AM
I personally wouldn't mix two under-drive pulleys. I'd pick one and stick with it.
If you have the engine apart, it's not a bad idea to replace the timing chain componenets. However we do not currently have a tech article for that procedure. You could grab a repair manual, it would be in it. Give our parts specialists a call, they will help you find the right manual and parts.
- Nick
