Great job on this article! This really helped me out alot! Now that I have the window actuator replaced and working fine, I have to lift the toggle switch up to lower the window and down to raise the window. Any suggestions?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I have not run into this problem. There could be a wiring issue with the new motor, the polarity could be switched. I would check with MINI to see if programming wil remedy the issue. As mentioned by another user below, he has heard this is a software issue.
I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick |
| All times are GMT -8. The time now is 06:07 PM. |
