-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Control Arm Bushing and ball joint Replacement (http://forums.pelicanparts.com/mini-discussion-forum/766751-question-control-arm-bushing-ball-joint-replacement.html)
johnk (guest) 08-19-2013 05:53 AM
Thanks for the great guide, but I'm currently having trouble removing the outer ball joint from the steering knuckle. The two 13mm bolts Figure 1 came off easily, but the joint itself seems to be firmly stuck in there.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-19-2013 05:53 AM
The ball joint is likely stuck due to corrosion. Use a soft-faced hammer (such as brass) and tap the ball joint around the perimeter until it is free.
- Nick
