-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Rear Shock and Spring Replacement (http://forums.pelicanparts.com/mini-discussion-forum/768055-question-rear-shock-spring-replacement.html)
Edison (guest) 08-27-2013 04:01 AM
what if i forget to line up the indentation like in figure 13
i just realized I might of forgot on one side, will there be any ill effects?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-27-2013 04:01 AM
That helps to get the spring in the correct position.
It depends on where it landed. The cap may not be all the way down on the upper spring bushing. Which could make it crooked when you tighten it. I would go back and realign the top cap.
- Nick
