How do you get the rear trim panel off? The seat-back in the rear hinges thru a hole in the panel. And how does one get the window up if the regulator is bad? I can hear the motor running and "crunching" noises. I would appreciate more detailed info for the rear regulator. Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
To remove trim panel:
-Remove rear seat bottom and backrest. -Open convertible top. -Unclip rear side trim clip at front of B-pillar. -Detach mucket from side trim at B-pillar. -Remove fastener at front of B-pillar trim panel. -Remove seat belt fastener on entrance cover strip. -Lever out expansion rivets. Release screw. -Unclip clips and remove side trim inwards and upwards. -Lever out trim panel clips on inner window cavity cover strip. -Carefully lever out window cavity cover strip with MINI special tool 00 9 317 towards top. -Remove outer window cavity cover strip. This is about as deatiled as I can get. I would grab a repair manual. It will have the procedure, special tools and torque specs. Give our parts specialists a call at 1-888-280-7799 - Nick |
| All times are GMT -8. The time now is 04:09 AM. |
