-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Installing A High Performance Coil Pack (http://forums.pelicanparts.com/mini-discussion-forum/770442-question-installing-high-performance-coil-pack.html)
weaselciuy 09-09-2013 05:00 AM
Hello,
The article says "will need four M6x50 bolts" but the picture has "along with 4 new M8x35 bolts" .
Which one is the right now? Im not good with bolts .
Thank you
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 09-09-2013 05:00 AM
You'll want to use M6 x 50mm bolts. Be careful when tightening. The factory bolts have a sleeve that prohibit them from being overtightened. The replacement bolts if overtightened may crack the valve cover.
- Nick
